LIPO BATTERY QUESTION
hey guys I just purchased a novak gtx esc ,and first of all, can I use any lipo battery(the instructions say 4 to 7 cell but for lipo??) ...and should I get a lipo cutoff module with this esc???.......HELP!!
Suspended
Since it clearly says on the Spec Page where you got the battery info
"Input Voltage: 4-7 cells or 2S Li-Po when used with Novak's #5470 Smart-stop Li-Po Module (#5470)" that you should get the LVC as they recommend.
Super Moderator
Trader Rating: 31 (100%+)
Any 2S lipo is o.k. you don't have to run a LV cut-off just make sure not to run your lipo down too far.
the battery im lookin at is a zippy flightmaxx 4000mah 2s1p 25c lipo.....would this battery be fit for tc racing??
Suspended
get that lipo cut off!!you dont want to ruin your new lipo
You need a 2 cell cutoff. The 2s in your description:
4000mah 2s1p 25c
Also commonly known as a 7.4 volt pack. (nominal voltage)
The 4 cell would be for a 4s, or 14.4 volt pack.
4000mah 2s1p 25c
