TC4 - LRP ESC - and LiPo Batteries?
Hi There...
I am new to this on-road thing and I just picked up a TC4 yesterday.
I was curious if the 7.2v 2s LiPo battery packs I have would work with the stock LRP ESC that came with the car?
They worked with my Traxxas Slash stock ESC... just no LiPo Cut-Off, so I had to be careful.
If it does work, can I purchase an independent LiPo cutoff for it?
Any drawbacks?
I have a number of 19t and 27t brushed motors that I just got used off eBay.. I also have a Lathe, so I am going to have to learn how to rebuild them. I am really concerned about motors overheating and burning up, as I have been guilty of that in the past. Any suggestions on Motor combos? Gearing? My motor was getting hot, so I geared it down. I believe it is now a 24t pinion, but it still seemed like the motor was getting really hot after 1 battery pack.
Any other suggestions or upgrades for the TC4 would be GREAT!!! I am totally new to this thing so I need to learn as much as I can..
Thanks in advance!!
Any drawbacks?
Thanks in advance!!
Not familar with teh TC4, but as far as lipo working - volts are volts, amps are amps, the esc can't tell any diff. If the possible voltage diff is bothering you - don't let it, when you pull a 6cell pack right off charger, that voltage is as higher as a 2S lipo anyway.
Def buy a lvc - you're one of the more diligent drivers to have not overdischarged a lipo running without an lvc. Here is one, there are others out there -
http://www3.towerhobbies.com/cgi-bin...&I=LXPGM8&P=ML
Only esc it will not work with is your Slash esc. Should be fine with yor LRP.
