ss5800 in xxx-t gearing question
what pinion should i run if i have a 86T spur and im running a ss5800 brushless setup at 7.2 volts? ill be running for 30+ minutes at a time and dont want it to start thermaling or shutting off
Suspended
I don't know that running it THAT long, at any gearing, would be especially good for it or that you'd be able to keep from thermalling because of the residual heat buildup that would inevitably happen.
have you tried 17/86?
