Go Back  R/C Tech Forums > General Forums > Rookie Zone
Whats wrong with me speed control! >
Old 01-13-2002, 08:30 AM
Crowder's Avatar
Default Whats wrong with me speed control!
i got a LRP forward and Brake for stock racing!
When i used it it suddenly started getting very hot and making a popping and sizzling sound!!!!! guess i need a new one but what went wrong with that??? had it about 6 months and have about 2hours use out of it????
What speed control do u recommened i get next! the price at me track is limited to 50 puond! 75 dolars! i was thinking a LRP ic Sport?????
Crowder is offline
Old 01-13-2002, 09:05 AM
Balak Racing's Avatar
Well, there could be any number of things wrong with it, but I'm going to take a few guesses. Since you are from England, it does get a little wet there. Was there a chance of any water getting inside your ESC? That would pretty much insantly fry it. How many cells were you using? If you were using more that the ESC could handle, that would do it in too. What kind of motor were you using? Some ESCs can't handle hot mod motors. I would send the ESC back to LRP and see if you can get them ot repair it for you. It might be cheaper than buying a new one.
Bryan
Balak Racing is offline
Old 01-13-2002, 09:11 AM
Crowder's Avatar
Hang on Just tried it again and it seems ok
it could well have got wet!!!!! theres a gap in the bottom (wher its coming apart) and it may have got wet??? its alittle dam out side!!!!!!
Crowder is offline
Old 02-01-2002, 10:20 PM
well i had a simaler problem but i had just started and when i put it in i had the wires on my dean plug backwards and it short circuted and it got REALLY hot and it smoked and also just wondering do you have exposed wire and heat sinks cause i learned that when exposed wire touches the heat sink the whole thing smokes and short circuts oh yeah and i have a dually and i suggest that you should look into novak esc's if you want a knew one
jepetto098 is offline
Old 02-03-2002, 03:15 AM
Alvin's Avatar
Hmm make sure u used schotty diodes on your motor?
Alvin is offline
Old 02-23-2002, 08:33 AM
Evil_S10's Avatar
Arrow
Another thing, make sure your speed control can take the motor you put on it.
Evil_S10 is offline
Old 02-27-2002, 03:00 AM
killer's Avatar
Sir im new to this hobby and i got a question, i own a TB-01 Mitsubishi Lancer EVO VI and installed Tamiya Type T super stock motor and an LRP Truck Digital ESC, now my question is with regards to my ESC motor limit it says in the box 35A and i am planning of buying modified motor to satisfy my need for speed, is it possible for me to install a 17x4 motor?or how many winds does a 35A motor have? does 35A means 35 amps?! thanks in advance!
killer is offline
