nimh charger? 50 dollars?
hey there ive just bought some nimh batterys to run my tt-01 but i need to find a charger i live in malaysia and my budget is about 150 rm or 50 us dollars
any suggestions of a cheap charger that will do the job?
How big are your batts? Here's one that will do an adequate job if batts are the right size -
http://www3.towerhobbies.com/cgi-bin...&I=LXEHB6&P=ML
Here's one thats a little above your budget, but it will charge any size NiMH od NiCd -
http://www3.towerhobbies.com/cgi-bin...&I=LXCLD5&P=ML
This is a solid charger and if you find one used, as long as it was not trashed, it would be a good charger.
Dynamite
http://www.redrockethobbies.com/Dyna..._p/dyn4044.htm
Dynamite Vision Peak 2. all NiCd or NiMh batteries out there, 4-7 cells
i have used for about a year and a half and it hasn't even blown its first fuse. for a 4200 battery, takes about 25 minutes, anything under, 20 minutes or less.
