Go Back  R/C Tech Forums > General Forums > Rookie Zone
Help - car running backwards >
Old 08-14-2008, 05:43 PM
TC3ElectricGuy's Avatar
Default Help - car running backwards
what have i done wrong.. the car is running backwards.
i tried changing the + and - wires on the battery to see if that would help, but it hasn't.
is there something i'm missing.
car starts perfectly though.
TC3ElectricGuy is offline
Old 08-14-2008, 06:08 PM
jatodriver93's Avatar
two possible reasons are that becuse your controller is reversed on the throttle input or your speed control is reversed
you can reverse the throttle on your controller or reset your speed control with the correct inputs
jatodriver93 is offline
Old 08-14-2008, 06:29 PM
it's a .21 nitro engine.
starter box direction seams to be correct, the starter wheel spins the right way.
when it kicks over it appears to pause for a split second then changes direction.
i read somewhere that it could be over primed... this engine was given a good shot of afterrun oil before shipped to me.
also the plug was extremely wet and for the obvious reason of the engine running the wrong way i stopped it almost immediately
Old 08-14-2008, 07:01 PM
Trader Rating: 21 (100%+)
Looking at the crank, engine should be turning over CCW. Check your starter box rotation, seen a few setup to turn wrong way.
These 2 strokes will start backwards, never heard it blamed on too much aro though, but if crankcase is loaded, it may be causing probs. I'd pull plug, turn it upside down and pull PS or turn it over with starter and try to get as much as possible out. Then, try it again.
Don't think you're doing any damage - especially stopping it as soon as you can. Usually its a curiosity more than anything.
Duster_360 is offline
Old 08-14-2008, 07:29 PM
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
rebuild ur diffs recently?
R
UltegraSTI is offline
Old 08-14-2008, 07:45 PM
KHoff7's Avatar
R
Im gonna go with that one.
KHoff7 is offline
Old 08-14-2008, 08:27 PM
yeah. i did rebuild my diffs only yesterday.. grr. means i gotta pull them out and turn them around.
quick. someone hit me, i'm a noobee.
will keep ya posted if that helps... i know the starter box is turning the right way.
Old 08-14-2008, 09:15 PM
right-e-o. all done. drives nice and forward now.. the diffs were the wrong way around... i did try the search function, but it wasn't working for me so i had to make this post.
my next step is tuning.. if anyone can give me a quick insight to waht needles i have to turn.
starts straight away and i mean straight away. will idle fine, but on the grass with accelleration it conks out. i ran it with the glow plug attached and it seamed to be fine...
idle appears perfect as the engine builds up a few rpm before clutch engages.
do i need to adjust the low end needle.
thanks again.
Old 08-15-2008, 08:38 AM
Suspended
advice #1 - you should have stayed with electric
advice #2 - do a search, a jog around the nitro threads to find nitro advice
advice #3 - refer back to your owners manual a reset all crab positions to their stock settings, and THEN ask questions while giving enough info for people to help diagnose your issues
advice #4 - start a new thread when you have a new question, otherwise you're threadjacking your own thread
advice #5 - see advice #1
szakcajaru is offline
Old 08-15-2008, 01:22 PM
pinky2252s's Avatar
pinky2252s is offline
Old 08-15-2008, 01:26 PM
pinky2252s's Avatar
thanks again.
Yup sounds like you need to adjust the low end, turn it clockwise, or in, about half a turn should work just about right
szakcajaru:dont tell people that they should of stayed with electric, itwas his choice to go to nitro.... and its about a million times more fun to run nitro
Old 08-15-2008, 07:25 PM
Suspended
pinky: adjusting 1/2 a turn is a LOT. carbs should be adjust an hour at a time, not six. how about holding off on giving advice on things you know little about.
I was only joking about the "staying with electric" comment, and I think anyone about the age of 10 would recognize it. he had the word in his handle if you'd bothered paying attention
Old 08-15-2008, 09:34 PM
pinky2252s's Avatar
yup nitro for 8 years and i know so little about it
you dont know me get off my back leave me alone
Old 08-15-2008, 09:41 PM
Suspended
get off your back? leave you alone?
you're the one that started the childish argument by correcting me, and you are also the one sending me childish PMs telling me what to do.
if you really knew anything about gas cars you'd never suggest telling someone to adjust anything half a turn not knowing where they were at to begin with.
get a life
Old 08-16-2008, 09:17 AM
Suspended
Location: r.i.p Chiquita - 1993-2008 - "best dog in the world"
now, now boyz
ratherBracin is offline
