car balance
car balance
i was wondering what is the best way to balance my touring cars front to back and side to side.is there more then one way is there any special tools you need.i saw some integy balancing balls? said something about drilling holes in chassis i really will not do that only at last option .anyone please help
Super Moderator
thanks guys i know to use lead weights,but how do i balance it i can't just stick on weights.is there an instrument or tool to check chassis unbalance from front to rear and side to side.do i find the middle (center)of chassis and dangle it by a peice of string?
Associate makes some lead weight in 1/4oz''s. DOnt drill holes in chassis will compormise strength etc.
Here u go.
http://www.losipartshouse.com/servle...Weights/Detail
Here u go.
can anyone please help me,i think these other guys are missing my question
Im not sure if theres a tool for it, but determining where to put weight is based on feel and how you want to setup the the car. I wanted more off power steering so i put weight in the front. from side to side you use weight to make the car lean more in the turns or to reduce the chances of traction roll. I usually use coins as weight if i dont have any lead weight.
I know what you are asking. Look about half way down here. It explains how to calculate weight bias using scales. It shows how to do it for a revo and front to rear but the same principles apply to a TC and side to side.
Super Moderator
I would say add as little weight as possible and focus more on preload on your shocks, that really helped me but I guess it doesnt work for everyone.
