Go Back  R/C Tech Forums > General Forums > Rookie Zone
Can someone breakdown Differentials for me ?? >
Old 02-20-2008, 08:07 AM
IL_AudiRacer's Avatar
Trader Rating: 58 (100%+)
Default Can someone breakdown Differentials for me ??
I have an xray m18 and while looking for option parts i have found several different differentials. can someone please breakdown the different ones and explain the advantages of them thanks.
Ball diff
Adjustable Ball diff
One way
im running on a small carpet track so what would be best suited
IL_AudiRacer is offline
Old 02-20-2008, 03:04 PM
beta bob's Avatar
Trader Rating: 2 (75%+)
From my understanding a ball diff lets the outside wheel spin faster then the inside wheel going through a turn. An adjustable ball diff lets you adjust how much slippage you have me and a one-way is a locked diff but when you use the brakes it keeps spinning. Thats just a rough idea of what they are.
beta bob is offline
Old 02-20-2008, 06:48 PM
Drifting101's Avatar
a one way is for a free flowing tracks with minamul and what it does is it has a bearing in it which is a ball bearing that locks up going in one direction and acts like a ball bearing.
A spool or a solid axil is for tight tracks with small straights. This helps you spin the tail out in the corner.
I personaly hate having a diff in the front
Drifting101 is offline
foams or rubbers?
i recomend a spool though(i know that you did not list but yea)
Old 02-21-2008, 03:13 AM
Pie_robot's Avatar
Trader Rating: 17 (100%+)
from wat i understand a ball diff up front is popular for foams on carpet.
Pie_robot is offline
Old 02-21-2008, 07:14 AM
tc3team's Avatar
Due to foams wearing unevenly easily I would never suggest using a spool with them as they will stress the drivetrain, always use a diff up front if you are running foams.
tc3team is offline
Old 03-02-2008, 03:47 PM
Thanks for all the info
I have just received my new Xray m18 and has (FRONT ONE WAY) installed what are the effects of this ??.im running on small carpet track with pretty tight turns and was having problem with rear end spinning out. should i just have reg BALL DIFF ??
i never realised how techinal this can get but im loving it
