Radio Problems
Old 02-16-2008, 09:22 PM
hrnts69's Avatar
Default Radio Problems
Ok, after getting done converting my Rustler into a Oval Truck, the radio is MESSED UP!!!
To go forward, you have to push up on the trigger, and to go backwards you pull back on the trigger. And when turning the wheel left, the truck goes right, visa versa. How do i fix this problem??? Iam having more fun with my XMOD and Zip Zap than my race truck!!! PLZZZZZ help me!
P.S. DONT test drive your truck in your room! Cuz i broke my glass mirror door, mom and dad aint to happy!
Blake
hrnts69 is offline
Old 02-16-2008, 09:27 PM
Trader Rating: 23 (100%+)
try to reset it and reconnect it to make a new strong wireless connection
or it could just be your trim
not home is offline
Old 02-17-2008, 05:53 AM
make sure the settings on your receiver are stock. such as the servo control etc..
bldiener is offline
Old 02-17-2008, 06:53 AM
hrnts69's Avatar
If this helps, iam using a Team Assocaited Radio system from a RC18T. Ive tried every button on it, could it be the ESC?
hrnts69 is offline
Old 02-17-2008, 08:08 AM
LOSI BOY-MF2's Avatar
Trader Rating: 80 (100%+)
I don't know much about the AE. radio but it sounds like the reversing buttons have been hit. Most radios have a setting that will allow you to reverse steering and or throttle. You should look at the instruction manual and see how to get it back to the normal setting.
If thats not it try resetting the ESC.
LOSI BOY-MF2 is offline
Old 02-17-2008, 08:50 AM
hrnts69's Avatar
Ive figured it out, had to reset the ESC back to normal settings
Thanks for the tips
hrnts69 is offline
Old 02-17-2008, 05:30 PM
magtataho's Avatar
magtataho is offline
