Question
#16
Slower is FASTER. If you can get around the track with out wrecking you'll be in good shape. Find a good speedyou can make a lap with out wrecking then after a couple of good laps try to speed up a little at a time.
The most commin mistake made by rookie's is trying to go faster than they can drive. Untill you can get around the track with out wrecking you wont be winning any races. Rember it just takes time and LOTS of practice.
Good luck
Aaron
Good luck
Aaron
#17
Well I got my first practie in on the local indoor dirt track... i think i did well over-all ... had some tumbles and spin outs.... i am offically HOOKED!! it was a blast i cant wait to go back tomarrow
#21
I wouldn't do any mods until it needs it. If you break some thing step it up from there.
And don't be to eager to win. Enjoy racing 1st and winning will come in time.
You will find a need for speed if your like most of us.
So go fast and try not to crash! Its more fun.
#22
yeaH...I FOUND OUT IT IS HARDED TO CONTROL THE CAR ON THE TRACK WITH JUMP-N-ALL RATHER THAN AT THE BASE BALL DIMOND...SO I AM GOING TO UPGRADE MY SHOES TO GET A BETTER BITE AND CALL IT GOOD FOR A LITTLE WHILE OR UNTIL I BREAK TO MOD MY CAR....THANKS FOR ALL THE ADVICE GUYS THIS FORUM IS AWSOME!!!!!!
#24
Well i tried some new shoes...it bites good now not much push...oh and i stepped up allitle also not much but here is the new addition
#25
i forgot to get the pic of the motor i wanted to put it in to test her out...its not much but alot more than what i had before.... well im of to the track for a little fun hope you guys like...
#26
Super Moderator
you can get a brushless 8.5 system for under $180 with esc !!! http://www3.towerhobbies.com/cgi-bin...&I=LXRST1&P=ML
its plenty fast for offroad
#27
ooh revenge of the monster , i remember running that motor way back in the day of brushed motors!!
#29
Keep the motor clean, here is a guide on how the motor is made up http://www.rccartips.com/rc-electric...ning-guide.htm
The commutator and brushes are the most important parts to keep clean. Make note of how the spacers are on the armature, which spring is on which post and always put the brushes back in the endbell how they came out.
If you keep the motor clean it will prolong the life of it, but eventually you will need to get the commutator re-cut.
hth
hth
#30
Great link, lots of good info there. Here is what I just bought, it is a peak commutator cleaning stick, it will clean both the comm and the brushes.
http://www3.towerhobbies.com/cgi-bin...?&I=LXUE64&P=M
