TOOLS
TOOLS
What tools do I need to rebuild my car
Thank you
Don't forget the freind that knows somthing to help.
Electric:
Basics:
Hex drivers (imperial or metric depending on what your car uses) selection of screwdrivers, good quality soldering iron and solder, knife for cutting lexan, scissors, tooth brushes and or smaller paint brushes for cleanig your car, pit towel, screw box, parts box(es), zip ties, camber guages.... plenty of other smaller items too that I cant think of right now.
May be useful but not 100% needed to start with:
dremmel or similar, spray gun and face mask, car setup station, motor dyno, comm lathe.
Basics:
Tool? This aint no gangsta forum y'know with guns a blazin'....
Thank you
Thank you
If you are talking about Touring Cars you may want to get a good flat set up board and ride height/droop gauge and in the case of a Corally and good torque driver (the older kits had the good red handle ones).
Thank
Thank You
What tools do you have
thank
thank you
