Go Back  R/C Tech Forums > General Forums > Rookie Zone
Measuring DROOP and RIDE HEIGHT? >
Old 09-26-2007, 09:28 PM
Renuco612's Avatar
Default Measuring DROOP and RIDE HEIGHT?
What is the right way to measure your droop? I am using the SPEEDMIND gauges and droop blocks. Do you have to use the blocks or can you put it just flat on the chassis? I have read on some TC5 setups the DROOP was 2mm REAR and 1mm FRONT for carpet with rubber wheels.
When I was setting my droop I tried to do that and it isn't possible if I use the droop blocks. or is it? I used the blocks and I got it at 6REAR and 5FRONT. is this right?
I'm pretty sure I'm using my ride height gauge right but it would be really helpful is someone can give me a quick HOW-TO so I can do it right. What is also the right way to adjust it?
Renuco612 is offline
Old 10-03-2007, 06:10 AM
Joel Lagace's Avatar
-Assuming all 4 shocks are built the the same lenght
I only use the droop blocks when im squaring up the car. While on the blocks use the guage to make sure that the left and right sides are the same, the front and rear will be different. Now that the car is symetrical. Put it race ready on a flat board. Set your ride heigh first. Now pull up on the shock tower and measuer the ride height at the point where the tires are just leaving the ground.
Subtract the ride height from that fully extened measurement and you have your uptravel(or droop)
EXAMPLE:
7mm(shocks fully extened tires leaving ground) minus 5mm(ride height) = 2mm uptravel or droop.
This is repeatable on any chassis and is the only way you can compare your car to brand xyz at the track.
Joel Lagace is offline
Old 10-03-2007, 03:57 PM
morris's Avatar
Trader Rating: 44 (100%+)
same as he said..make sure your shocks all the same size.
i dont have blocks...but if it says 2mm in the back and 1mm in the front...
i back out all droop screws,
set ride height to desired height, (example 5mm)
then in the front i set the chassi on the 5mm slot.screw the droop screw untill the tire lifts off of table.slowly back it out untill it rests on table.do the same to other front and that is 1mm of droop.
repeat the same process to the back but instead of 1mm its 2mm.
hope this helps.
matt
morris is offline
Old 04-19-2009, 11:01 AM
Team Ewing's Avatar
hope this helps.
matt
Hello from Memphis,
I've been trying to get my head around this "droop business for quite some time now. This is the simplest explanation that really turns the lights on for me. Thanks guy and good racing to ya. Ron.
Team Ewing is offline
Old 04-20-2009, 02:13 PM
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Wouldn't that be 0 mm droop? Or did you mean you set the chassis on the 7mm slot?
Cpt.America is offline
Old 04-20-2009, 02:22 PM
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
xray setup guide, download it now and take it with you to the track every time
R
UltegraSTI is offline
Old 04-20-2009, 09:56 PM
i just use a ride height guage for checking the droop and ride height.
ill settle the suspension on the table and check the ride height.
if its 3mm then i lift the car/truck and check the fully extended height.
subtract the ride height from the total extened number and that is your droop.
jaredmausteller is offline
Old 04-21-2009, 09:17 AM
R
Holycrap the Xray setup guid book is awesome! They outline every single setup technique, for each aspect of the car, fully detailed, outlined, pictured, and in order. Incredible.
