Go Back  R/C Tech Forums > General Forums > Rookie Zone
Gear Ratio Application??? >
Old 05-11-2003, 04:22 PM
I'm new to the r/c hobby and I need help trying to figure out how the spur / pinion gear application works. I know it tells you how many turns your motor makes etc. what I really need is to know is how to set up for each different track. Thanks
rulis is offline
Old 05-11-2003, 05:30 PM
Suspended
Well first what car and spur are you useing now?. I us a 87 spur and 18 pinion. It also depends on the motor your useing. I use that ratio for monster stock bt for a P2K2 i found that going up a couple teeth worked better for it. If your motor is burning hot and draining your packs befor the race is over it is over geared. What i do is just keep tying diffrent pinion gears untill i find what works the best. So what car,spur gear an motor are you useing then i can help you with the ratio better.
R C king is offline
Old 05-11-2003, 07:43 PM
Unhappy
I have a Yokomo MR4 it has an 87 spur and a 23 pinion. This chassis has a limited space for the spur gear so I don't think I can go much bigger.
rulis is offline
Old 05-11-2003, 07:45 PM
[QUOTE]Originally posted by rulis
[B]I have a Yokomo MR4 it has an 87 spur and a 23 pinion. This chassis has a limited space for the spur gear so I don't think I can go much bigger. I run a 27 turn stock motor
rulis is offline
Old 05-11-2003, 09:41 PM
Suspended
What is the motor called? and it is over geared try going to a 18 or 19 pinion thats what i use. It hapend to me befor and i had a 23 pinion on a 1/10th scale pan car then put a 15 pinion on and it went faster and ran perfect. But what is your 27 turn moor called.
R C king is offline
Old 05-12-2003, 06:52 PM
I run two types of motors one is a PMR Code Red and the other is a Monster (the one that has a Godzilla on it) I also forgot to mention that I was running on an inside carpet track but now that winter is over I'm gona run on a paved track thats much bigger than the carpet one. Thanks.
rulis is offline
Old 05-12-2003, 10:58 PM
Oasis's Avatar
Trader Rating: 38 (100%+)
The stock spur gear for an MR4TC is 81,With your gearing your final ratio is 8.32,you should be in the mid 7s,I would use a smaller spur gear(82) and run a 24 pinion.The trany ratio for your car (MR4TC) is 2.2:1.The final ratio is for a monster stock (7.52)With a P2K2 I run an 82/26,but I race on a small track so if your track is large you might want to go up a tooth or so.
Oasis is offline
