Go Back  R/C Tech Forums > General Forums > Rookie Zone
Nitro receiver packs >
Old 12-05-2001, 02:20 AM
I've still got the good old 4 x AA receiver battery pack.
I've seen guys with 'hump packs' or rechargable packs.
Can anyone tell me what Voltage and mAmps or whatever i may need for my TS-4N, cause i was going to get a new pack via mail order?
Also, will i notice much difference in the performance of the servos?
Thanks guys
Glenn is offline
Old 12-05-2001, 11:06 PM
Trader Rating: 82 (100%+)
try to get the battery pack with the highest amp rating. also, determine if the pack will fit in your nitro car because you may have to find a new location, considering youre gonna use 5 cells instead of 4. if you were using 4 nicads, you will notice a difference in your servos if you switch to 5-cell packs. the extra 1.2volts will deliver more power.
marvi is offline
Old 12-07-2001, 03:12 AM
fatdoggy's Avatar
Switch to 5 cells you'll get more voltage and longer run time.
fatdoggy is offline
Old 12-07-2001, 05:12 AM
RCTech Member #2
TSR6's Avatar
Don't use a 4 cell RX pack. They have a slightly smaller voltage than a 4 cell alkiline has. ( Rechargables have less volage ). A 5 cell pack is really what you need.
Trinity, Ofna, Dynamite, mugen all have RX packs. They have Flat Packs(all flat in a line), hump packs(3 cells on the bottom, 2 on top) , and a different hump, 4 on the bottom 1 on the top.
TSR6 is offline
