Go Back  R/C Tech Forums > General Forums > Rookie Zone
car goes out of control... >
Old 04-27-2003, 07:13 PM
traxxasdude's Avatar
Default car goes out of control...
when I hit speeds around 35 mph it will steer without me telling it to I'm going to charge the transmiter batts and I'll post if it works or not but right now I can't run it because one of my good motors got a nut stuck in it and busted the endbell, still waiting for p2k2 pro .
traxxasdude is offline
Old 04-27-2003, 10:53 PM
Suspended
how far are you running it away from you? Because it might be getting out of range.
R C king is offline
Old 04-28-2003, 02:17 PM
I doubt it is going out of range because it will still respond to me but occasionally it will all the sudden jerk to one side. I just charged my controller batts and broke in my pulse r and so I will test it and tell you the results.
Old 04-28-2003, 04:29 PM
lost my 19t pinion gear luckily I ordered a 23t pinion gear 1 week ago (still hasn't shipped )
Old 04-29-2003, 02:32 PM
found pinion, trickle charging batt to make sure it doesn't have anything to do with it.
Old 04-30-2003, 10:40 AM
Suspended
You didn't cut the anntena. did you?
R C king is offline
Old 04-30-2003, 03:27 PM
no, but my t-4 esc says I should install all these capasitors, do you think that could be the problem?
Old 04-30-2003, 03:30 PM
Something rubbed in to the switch and turned on my transmitter for about 12 hours another school day to go to then just maybe it will work.
Old 05-01-2003, 05:50 PM
Oh great, My tl pinion gear won't work with my tamiya.
Day 9 of the great wait for parts off of stormerhobbies.com
Old 05-02-2003, 07:44 PM
went to lhs, they don't carry tamiya parts
Old 05-02-2003, 09:58 PM
Suspended
Just check your hobby store.
R C king is offline
Old 05-03-2003, 06:29 AM
I said that I just went to my lhs (local hobby store/shop)
Old 05-09-2003, 07:03 PM
sorry for waiting so long to tell you that it seems to be working fine
Old 05-10-2003, 12:00 PM
Suspended
Well thats good.
R C king is offline
Old 05-10-2003, 04:11 PM
I found my problem. the anntena was tangled around the reciever.
