Go Back  R/C Tech Forums > General Forums > Rookie Zone
newbie tuning >
newbie tuning
newbie tuning
Old 07-01-2007, 10:20 PM
Default newbie tuning
I just bought a traxxas revo 3.3 and im having trouble tuning it. iill get it set so a perfect idol then work with the main carburator screw, when i throttle up it will either a: take off at a good clip then die from anywhere to 10 to 50 feet, then i cant restart it for a while, or b: hesitate a bit than die, but i can start it right up. any input would be great thanks.
Revo_Ranger 4x4 is offline
Old 07-01-2007, 11:20 PM
vios8820's Avatar
Trader Rating: 65 (100%+)
this is juz for u bro...
http://www.youtube.com/watch?v=pEGjExP9GkM
hope it help
and also this maintanice are improtant
http://www.youtube.com/watch?v=LoLFuoL09ko
gud luck.. btw where are u from ?
vios8820 is offline
Old 07-02-2007, 06:07 AM
MADMAN23's Avatar
Trader Rating: 27 (97%+)
Talking
what temp is it runing at?
MADMAN23 is offline
Old 07-02-2007, 07:49 PM
vios8820's Avatar
not more than 270F i think
vios8820 is offline
Old 07-07-2007, 07:36 PM
atebit's Avatar
maybe try to reset the high speed to factory settings and try tuning from there.
also if you dont have a temp gauge its a good investment for 20$ or so.
real fast temp check!
or try putting a drop of water/spit on the engine head,
if it sizzles immediately thats too hot. it should take a
few seconds. thats kind of a bad way to do it tho.
i'm fairly new to the hobby but this may help.
keep up the attempts!
atebit is offline
Old 07-08-2007, 06:21 AM
Wild Tiger's Avatar
Try richening up the bottom end (Low Speed Needle), how much smoke is coming out of the exhaust when you take off, it should be very visible.
If bottom end is too lean, it will take off and die coz it's starving for fuel.
You have "run in" the engine, right?
Wild Tiger is offline
Old 07-09-2007, 01:27 PM
jatoman1992's Avatar
Trader Rating: 4 (75%+)
ya if you dont break it in ur 3.3 can break the crankshaft...trust me it happened to me and one of my friends
jatoman1992 is offline
Old 07-09-2007, 04:40 PM
its broken in properly, it just took a lot of playing with the screws back and forth to get it perfect. it runs great now, i just keep breaking things, tires, servos etc.... I got a lot to learn, my friend also got a revo and your guys' info helped a lot thanks.
Old 07-11-2007, 04:01 AM
Wild Tiger's Avatar
Glad we could help
