Spectrum issue
Spectrum issue
I just got a spectrum system, and installed the two receivers. However both receivers seem to have an issue turning left, the turn all the way right, but not left. On two different cars, a b4 and a 18t. I have set the throw as far as I could, and then set the trim all the way to the left, and still it barely turns that way.
When i unhook the spectrum receiver and plug in the 27 mhz rtr associated reciever, bam turns left perfect, same servo same settings etc...
What am I doing wrong? Is there a setting on the transmitter i am missing? I'm thinking transmitter as it is the only thing that doesnt change between the two cars, receivers, and steering servo...
help?
help?
take a look at your epa's(end point adjustments) on the radio. your right is probably set higher than your left. what radio are you using?
