Go Back  R/C Tech Forums > General Forums > Rookie Zone
motor over heating >
motor over heating
motor over heating
Old 04-05-2003, 05:22 PM
Default motor over heating
im runing a xx4 w/10x2 team orion chrome modified motor w/20 pinion and i think a 84-87spur gear,novak dually.ok i tryed this motor out on a crapy blast esc with the same gearing and only the esc got hot(no wounders hehe)but today i installed the dually and the motor gets very hot but nothing else,it was getting so hot you could smell it.what could be couseing this???
thuglove is offline
Old 04-05-2003, 05:59 PM
fatdoggy's Avatar
Try a 17 pinion and a 84 spur. I think your overgeared. But I'm not sure(I've never run offroad). Check your drivetrain for debris.
http://home.att.net/~casper04/Gear_Chart.htm
fatdoggy is offline
Old 04-06-2003, 05:30 PM
jallshouse's Avatar
you may want to double check your gear mesh...i had a xx4 once, and the gear mesh was a pain in the to get right. if you have it too tight you will get the problem you are describing
jallshouse is offline
Old 04-07-2003, 01:59 PM
OVA
OVA's Avatar
Trader Rating: 85 (100%+)
go to losi web site and ask question there
OVA is offline
Old 04-22-2003, 04:30 PM
Suspended
Go down a few teeth.
R C king is offline
Old 04-26-2003, 08:40 AM
traxxasdude's Avatar
10t off-road is way to little. Try getting atleast 15t.
traxxasdude is offline
Old 04-26-2003, 12:48 PM
fatdoggy's Avatar
Traxxasdude? What do you mean, if he's running mod 4wd buggy he'll probably need a 10 turn motor to keep up, a 15 turn is way to slow for mod buggy if you want to be competative.
fatdoggy is offline
Old 04-26-2003, 05:54 PM
Suspended
yeah.
R C king is offline
