Go Back  R/C Tech Forums > General Forums > Rookie Zone
what setups help braking >
Old 04-08-2007, 04:23 AM
Arrow what setups help braking
hey guys
in my driving i am now trying to control my braking and i would like to now what type of setup on a mf2 losi stock truck will help this?
03phillipsr is offline
Old 04-09-2007, 07:08 AM
If you're talking about locking up the wheels and sliding every time you brake you need to dial down your brakes. You do this by having a radio with adjustable EPA and you set up your ESC with full end points then turn down the brake end-point until it is more controllable. Some ESC's have settings that let you adjust the brakes as well.
If you don't have either of these (or if you have a LRP AI ESC), you need to learn really good finger control...or maybe someone else will have more ideas.
glitchy is offline
Old 04-09-2007, 08:26 PM
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Could be your drag brake set to high on your radio. Probablt causing your car to rotate around a corner when your off throttle.
BuggyKing is offline
