Go Back  R/C Tech Forums > General Forums > Rookie Zone
New need help please >
Old 02-19-2007, 04:23 PM
Default New need help please
First of all I am real new to this.
1st Question on this picture with the arrow is that the low speed needle adjuster
2nd Question on the exaust is it normal to spit fine bits of wet fuel out.
3rd does the car need to make a white smoke when idling or only once its driving
PLease help...THANKS
rex-x mick is offline
Old 02-19-2007, 04:41 PM
Paradoxmaker's Avatar
Depending on the motor thats either the low speed needle or mid range needle (if it's a 3 needle carb). What motor is it?
If your spitting unburned a lot of fuel out of the pipe, your running rich. Also if your idling for a significant amount of time then your engine will build up unburned fuel in the block and that will be expelled when you throttle it up.
Paradoxmaker is offline
Old 02-19-2007, 04:54 PM
i am not sure but the booklet says 21R/ABC is that what my engine is
so if its to rich do i adjust the low speed needle.
Old 02-19-2007, 09:43 PM
amain's Avatar
no. never adjust the low speed first. always the high speed. its the big long one that sticks out going up where the fule niple comes from. if ur spitting fule out right now turn it in (leaning it out) 1/8 th's of at a time. until at full throttle u have a nice blue/white line of smoke and u have a nice sound to it to
amain is offline
Old 02-19-2007, 10:08 PM
Illbreakthat's Avatar
Thats right adjust the highspeed for power than attack the low speed.... the needle that your pointing at IS a MID needle the low speed will be at the end of the other side of the carb. Yes you should have smoke coming out if not then its running lean on the low end. I hope this answered your questions.
Illbreakthat is offline
Old 02-19-2007, 11:58 PM
one last thing.
it kept happening this arvo.
when ever i pulled out the glow plug charger thingy
it kept cutting the motor out. what could this be
Old 02-20-2007, 12:30 AM
steelhawke's Avatar
Yes that was the low speed needle, the tall one is your high end. If I remember correct it was like 2 1/2 turns out on low and 3 1/2 on high for factory setting(21=size r=race ABC=type of sleeve). I've had motors spit fuel while running awsome, it should be a very tiny amount thou. This means it is on the rich side but I like to get as much life outta my motors as possible. I only bash around these days with nitro so why push it. I've blown motors runnin them lean and maxed one day. Only to run another day with a 12 degree temp differance and forget to richin up a click. Insta paper wieght. Amain and illbreakthat(love the name btw) mention the keys to running nitro; watch for that smoke trail,never over adjust the carb. Getting a temp gauge too if you don't have one. Watching the motors temp helps you tune the carb aswell.
steelhawke is offline
Old 02-20-2007, 12:33 AM
steelhawke's Avatar
Shoot just saw your last post there. If the motor is spitting fuel and killing after your taking the glow igniter off. ITS TO RICH.
Old 02-20-2007, 12:53 AM
it aint spitten no more. its just got a nice thin white smoke. so if it cuts out once i remove the glow charge, its still to rich
Thanks everyone for helping me I really appreciate it...
the red arrows show my screws,in the manual it says
high speed
low speed
and idle
the blue arrow indicates where it should be a low speed but there is no screw i have double checked
Old 02-20-2007, 06:52 AM
LogiK's Avatar
Trader Rating: 11 (92%+)
Its on the end of the carby slide normally.
LogiK is offline
Old 02-20-2007, 12:20 PM
i know where you mean but there is no screw there
Old 02-20-2007, 01:50 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 201 (100%+)
if that is a OS motor then that is the low end needle thats how the carburator is on the Max engines
Marcos.J is offline
Old 02-20-2007, 11:19 PM
i just got it tuned and runs sweet now.
Old 02-22-2007, 11:27 AM
Super Moderator
Marcos.J's Avatar
good for you
Marcos.J is offline
Old 02-23-2007, 07:25 PM
here is the next problem
I got it tuned then replaced the clutch bearings an clutch shoes.
but my question is when i start her up , have a little drive then come to a stop on concrete then let go of the brake. It starts to creep forward when it just idles.
and when i lift the back wheel up it just builds up wheel speed.
Is this normal
whats causing this.
PLEASE HELP Confused
