Go Back  R/C Tech Forums > General Forums > Rookie Zone
Battery mAh levels? >
Battery mAh levels?
Battery mAh levels?
Old 01-14-2007, 11:02 AM
Default Battery mAh levels?
Hi guys, real noob question here but I need to replace my 9.5v 600mAh battery, and I'm wondering if I can replace it with an 800mAh one?
If so, would it work or would it damage the car?
Are there any benefits to using certian mAh's over others?
Thanks for taking the time to answer!
Beercan is offline
Old 01-14-2007, 11:29 AM
budachi's Avatar
As long as the voltage is the same then - Yes. Simply put , a higher mA rating just means more stamina , ie it has more current available so will last longer.
budachi is offline
Old 01-14-2007, 02:03 PM
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
That would be fine, as long as the volatage is still 9.5v (in otherwords, the same about of battery cells) than you will have no problem
Cheers
Drift_Buggy is offline
Old 01-15-2007, 12:44 AM
ProudSavageOwnr's Avatar
if its a radioshack car i would not realy bother..........but yes you can put a higher MAH battery......try getting the highest MAH avalable in that kind of battery and try be it NIMH not NICD
ProudSavageOwnr is offline
Old 01-15-2007, 02:26 PM
Thank you for your advice guys. Much appreciated.
Beercan is offline
Old 01-23-2007, 01:43 AM
steelhawke's Avatar
What exactly does mAh do and stand for on a pack? Just milli amp hours right? So just longer run times I'm thinking..
steelhawke is offline
Old 01-23-2007, 04:24 PM
Super Moderator
Grizzbob's Avatar
Exactly right, basically is the same as adding a bigger gas tank to a full scale car.....
Grizzbob is offline
