Receiver antenna wire replacement
So basically on my Novak xxl receiver, the antenna ripped off and my Airtronics receiver the antenna ripped in two. Does Radio Shack carry replacement wire? If so whats it called?
If the reciever is not under warranty theres no harm in carefully opening the case and seeing for yourself if you would feel ok replacing it
If you do decide to do it yourself try not to overheat the curcuit board when youre soldering on the new wire (could possibly be done with a too higher wattage soldering iron) and find out what length the replacement should be first.
