B4 To X6?
Old 01-09-2007, 06:26 PM
BayArea101's Avatar
Lightbulb B4 To X6?
Whats the whole deal with converting the Associated B4 into a X6?
How does this work? What do I need? (Would it be better if I converted the Factory Team buggy instead of the Regular Stock Buggy or do the X6 parts replace all that) *Hope that made sense...*
Is is worth it? What will it do? ...Pretty much, everything!! =D -Thanks
BayArea101 is offline
Old 01-23-2007, 05:00 PM
westcoast_racer's Avatar
From what I've read about it, the regular team buggy will be a good candidate, but the factory team will give you the better shocks, lightweight outdrives, titanium goodies like turnbuckles and other cool stuff. Basically, you use the entire front end from the B4, the transmission gears, CVD'S, Hubs, tires. The Conversion kit comes with a new chassis, new trans case, new body, rear shock tower, rear arms, and other little parts they have made to make the buggy their own. Im thinkin about gettin one to try it out, but then again im using a factory team B4. It looks cool and is unique, So im gonna give it a shot. I mean if Brian Kinwald stands behind its gotta be good right
westcoast_racer is offline
Old 01-23-2007, 05:07 PM
BayArea101's Avatar
Thanks... but I already decided to go 4wd instead
Old 01-24-2007, 08:57 AM
BuggyKing's Avatar
Trader Rating: 17 (100%+)
What 4wd buggy are you looking into?
BuggyKing is offline
