what kind of grease?
Hi,
I'm new to the rc world and just purchased a tamiya tt-01 kit to start off. I have one question, in the manual it says to apply grease in multiple places, can I just use 100% pure silicone grease? thanks
i second that
however how often should you regrease ball diffs and such
Generally you can feel the diff and if it starts feeling a little grindy then it's time to change the diff rings or just flip them. Then you clean the diff I use motor spray, afterwards you can use the Associated clear grease to reinstall your diff balls and reassemble your diff again.
i had one more quick question about grease...
is there anything i can use for grease that i could buy at a local hardware store ?
