Upgrading Shocks
Upgrading Shocks
Right now i have the stock shock that are not adjustable threaded ones... they are the one that u place the spacers in to make adjustments.... i have a large variety of spacers so i was wondering it i should upgrade to the new threaded shocks? If so wats a good company for these? my car is a NTC3 Plus. Thanks alot
Tamiya Flourine coated shocks are good, but the Team Associated Factory Team aluminum threaded shocks will work fine too. For racing I wouldn't go with Integy or Hot Racing, but they are threaded, they are aluminum, and they are on the budget side.
I think the price of the ae shocks are around $50.
So i should upgrade the shocks?
Super Moderator
That's really up to you, threaded shocks don't make them dampen any better than a stock one does, but threaded ones are a lot easier to make ride height adjustments with. But in general, you will get the same handling either way(plus, with those AE shocks you have, it is possible to just buy threaded shock bodies instead of complete shocks, just replace the bodies when you rebuild them, which should be done on a regular basis anyway)....
Thanks... i never really though about that... thatnks alot
