Setup systems question
Hello ,
as a rookie myself i want to know if droop gauges and support blocks are the same for 1/10 and 1/8 scales. I dont want to buy them twice.
Thanks in advance.
Thanks in advance.
they are not the same, the 8th scale blocks and guage are taller, but they all measure in MM. Hudy makes a nice set for both, and you can use the 8th scale ones for 10th scale, just your reference numbers will be different but once you figure it out, it all works the same.
