Go Back  R/C Tech Forums > General Forums > Rookie Zone
Yeah racing universals >
Old 02-07-2024, 10:20 PM
Default Yeah racing universals
Hi Lost the little clip that holds the two pieces together. Anyone Who knows if you just can by the clip? Maybe there is some standard. Cant upload pictures, new in the forum.
Stefanwiberg is offline
Old 02-08-2024, 04:59 AM
rustyus's Avatar
The "clip" that keeps the pin secure in the CV joint? What is the Yeah Racing part number of the item in question?
rustyus is offline
Old 02-08-2024, 03:22 PM
https://www.yeahracing.com/contact-us
BigBuckORamma is offline
Old 02-08-2024, 09:16 PM
Hi
YR-TAXV-012SP is the partnumber on tamico.de
Old 02-08-2024, 10:33 PM
And I have contacted yeah racing but they just said to buy new one and to use adhesive threadlock. Trying to get an answer what they mean by that, cant see what that should do diffrently.
Old 02-09-2024, 04:00 AM
DirkW's Avatar
Weird answer indeed. I'd get it, if these were using grub screws, but with clips?
Just to make sure, we're talking about the clip that secures the little pin that actually holds the two halves together, right?
DirkW is online now
Old 02-09-2024, 05:09 AM
rustyus's Avatar
I would just find some heavy gauge steel clips at auto parts store to fit in the groove.
Use some muscle, and pliers to bend into shape. There is one video that I've seen a person used an old shock spring coil, but I don't know if that would be enough to hold CV pin securely.
rustyus is offline
Old 02-09-2024, 10:20 AM
Yes exactly! Hope it doesnt happen again
Old 02-09-2024, 10:29 AM
DirkW's Avatar
Make sure you install them the right way round. In Tamiya manuals this is usually pointed out specifically, as when the clip is just minimally raised, it can hit the wheel hub. If installed correctly, the hit will press it down again, if incorrectly, it can make it come loose completely.
DirkW is online now
Old 02-09-2024, 11:23 AM
The yeahracing came ready just go in the car. No assembly needed and no instruction. Guess that you get what you paid for but still 🤣 but a valid point, atleast give a look
Old 02-10-2024, 03:52 AM
Roelof's Avatar
Rubber O-rings?
Finding a spring that size so you can cut off one coil?
Or bend something from piano wire?
Roelof is offline
Old 02-10-2024, 10:12 PM
Originally Posted by Roelof
Rubber O-rings?
Yes I have to look into it. It was more if this piece was some kind of standard clip just that I dont know the name of it 😊 thanks for all tips!
