How do i fix this?
Hobbywing esc not sure on the motor
https://youtube.com/shorts/n0h88uHsKug?feature=share |
Dead batterty, re calibrate esc to transmitter. new esc.
Where's the sound coming from? Can you tell?
Sounds like one of the 3 motor wires has lost connection.
sound comin from motor.
Yeah I had the problem once, check the soldering on the connections to the motor, and the ones on the battery too while your at it. even a loose connection can bounce around with the vibration of the motor. Sorry if this thread is dead, or if you already solved it lol
| All times are GMT -7. It is currently 01:31 AM. |
