Stuck Screw
Hey yall, just picked up a used Team Associated B6.3D B74.1D and the screws on the under side are really in there any recommendations on how to get them out?
If it's metal on metal and the head is stripped out . Drill the head off Then use heat if needed and then vise grips to remove screw.
use a piece of dry ice then try the tool that goes into screw 1st dont drill head off ..
Originally Posted by the rc guy
(Post 15974394)
I'd just drill the head off. If you try to slot it you're just going to mess up your chassis.
Stripped screws
I always use these,works every time.Hope this helps ,one of the best tools I own.
https://cimg7.ibsrv.net/gimg/www.rct...17ca76bdc7.jpg https://cimg8.ibsrv.net/gimg/www.rct...09bb0d8801.jpg |
Originally Posted by martind1318
(Post 15974476)
I don't know how small those thingys are but if they're small enough I think I'd try them before I drilled the head off. Might just work. You can still drill the head off if they didn't work. I've seen them advertised but not seen them in real life. Kinda thought they were a gimic but don't know for sure. I've got some real small easy outs but being as small as they are they are a tad brittle and you don't want one broken off in the hole. At that point you're truly screwed. I buy tools I don't need all the time. I love tools.
Originally Posted by 1995 Monster T
(Post 15974553)
They don't work if the head of the Fastner is missing. Then you're back to slotting. Just another tool you don't need.
You are going to have an impossible time trying to slot the shaft of a screw in a counter sunk hole. |
Originally Posted by BigBuckORamma
(Post 15975668)
If the head is missing, remove all the other screws, and remove the part with the threaded screw still stuck in it, and get out a pair of vice grips to unscrew it.
op has never said screw heads are missing.. he want a way to remove screws. those were given.op never replied to anyone's reply
(Post 15975968)
good enough.. whats with all the ? .lol
He gets confused sometimes.
