Go Back  R/C Tech Forums > General Forums > Rookie Zone
Best Fuel to run >
Best Fuel to run
Like Tree12Likes
Best Fuel to run
Old 10-28-2022, 01:52 PM
  #16
1995 Monster T's Avatar
ROFL...................
1995 Monster T is offline
Old 10-28-2022, 07:34 PM
  #17
fyrstormer's Avatar
Originally Posted by Ivorycu View Post
Hello,
Just bought a SH .28 8 port engine.
What is the best % of Nitro Fuel and Oil % to Break in Engine and to continue using?
I use 30% nitro with 11% oil, which I raise to 12% by adding a shot-glass of natural castor oil to each gallon. The tiny amount of natural castor oil allows the fuel to build up a small amount of varnish inside the engine over time, just enough to improve lubricity and fill in microscopic scratches.
The big thing is to take apart the engine before using it, check for any burrs along the machined edges (especially the ports on the sleeve), and deburr them with a diamond jewelry file. Then wash the parts and reassemble with a bit of oil. That way the burrs don't have to be scraped off by the engine parts themselves during the break-in process. After the first tank of fuel, remove the heatsink and wipe the inside of the cylinder with a cotton swab to remove any bits of chrome that flaked off the edges of the ports but didn't get blown out the exhaust. Then reinstall the heatsink and resume break-in as normal.
This method has worked perfectly for me for most of the time I've been RCing. I haven't had to replace an engine due to wear-and-tear in years.
petersen114 likes this.
fyrstormer is offline
Old 11-09-2022, 07:15 AM
  #18
Roelof's Avatar
So you can not win from the experienced guys on this forum so now you gonna tell the rookies the same crap?
Originally Posted by 1995 Monster T View Post
14-18% oil lube.
Most RTR fuels have 12 to 14% oil, more can give tuning issues so it is not advisable. But the question was about the nitro content.
9% is race fuel and 16% is backyard bashing fuel. You will not be able to tune a engine the same with different% of oil lube. Less tunning with less % oil lube.
Huh? lean is still lean and can cause detonation. Agree that a basher does not need 9% but if he/she knows how to tune then 9% will work perfect.
YEA??? Your tuning window is smaller and your engine has less protection from a lean run and your engines run hotter. Oil lube dissipates heat and cools the engine.
Too much oil will give resistance and resistance will be transferred to heat as well. More oil will give a different tuning but no wider or smaller window.
NitroRC.com | Fuel Mixture Workshop
This is where I got my info from not out of the air like you. LO
Your engine is running toooo hot. Normal should be around 200 Degrees or less for .12-18 size engines. Mine run at 175-200 degrees. .21 at 225 degrees. All those years of running didn't add up to much!!!!!!!! It's the gallons that tell the story. 2 cases a summer for me. I guess you run quarts!!!!!!!! So stop giving bad advice!!!!!!!
Engine temps are not always as you say. First of all there are huge differences between IT temp meters but also their correction on plain aluminum or anodized aluminum can be far off. But to give you an example, my .21 engines run 150 degrees C (!!!) and I have a stock Kyosho .18 engine running 170 degrees C (!!!)
I think @mrreet2001 needs more popcorn....
Bud, petersen114 and mrreet2001 like this.
Roelof is offline
Old 11-10-2022, 08:45 AM
  #19
Bud
He's not smart enough to argue with so I gave up. 175 degrees Fahrenheit isn't even hot enough to tune properly.
Bud is offline
Old 11-10-2022, 09:18 AM
  #20
Yes It is for a smaller engine! Location location location.
Old 11-10-2022, 11:10 AM
  #21
Bud
Please explain to me the location where 175 degrees is hot enough to tune a 12 nitro motor.
Bud is offline
Old 11-10-2022, 11:25 AM
  #22
mrreet2001's Avatar
Well the temperature wasn't on nitrorc.com so he just made it up. lol
mrreet2001 is offline
Old 11-10-2022, 12:10 PM
  #23
I don't make things up like you. I posted my actual results for my engines! I have well over 60 + running nitro engines!
Old 11-10-2022, 12:13 PM
  #24
Bud
again
Bud is offline
Old 11-10-2022, 12:15 PM
  #25
mrreet2001's Avatar
What exactly did I make up?
Old 11-10-2022, 01:00 PM
  #26
Roelof's Avatar
Oh wow, can I touch you?
Bud and petersen114 like this.
Roelof is offline
Old 11-13-2022, 02:40 PM
  #27
petersen114's Avatar
lol
petersen114 is offline
Old 11-23-2022, 08:42 AM
  #28
im also watching
Lance Merrick is offline
