Racing club - What car to make our "standard" racing is fair
Well a lot depends on local availability but the Tamiya Eurotrucks are a popular low cost class, keeping upgrades to the bare minimum.
TT01s (or TT-02s) with touring bodies can be run to similar simple rules.
Or Tamiya Minis are a popular simple class. Normally you'd allow more hop-ups but with limited gearing and a brushed motor it's still an inexpensive class.
I've put a lot of thought into this. And.. I keep coming back to the TT02. It's a car you can build in a couple hours. It's a car that if you REALLY screw it up, you're never out more than $20, and 10 minutes.
The downside of "hobby grade build" is you're now hanging people out to dry with servo choice. Also the TT02 comes with a really bad servo saver. It means the information package you need to give to a new driver is a bit bigger.
Traxxas 4Tec 2.0
It's not a "race car" by any means, but for a fun, consistent, easy, fast, plug-n-play option you can't beat it. Several tracks are starting to run spec 4Tec classes. With USGT tires, a better servo, radio and body it's actually pretty decent to drive... sounds like rocks in a blender though.
Tamiya TA02?
Widely available as Tamiya keep ReRe'ing it, relatively cheap, and better than a TT01/02?
Or M07? No hopups needed as great out of the box. Or stock M05 with only bearings and hardened pinion allowed as an upgrade (cheaper kits than the M07/08 and include a body).
Tamiya TA02?
Traxxas 4Tec 2.0
This topic was pretty much covered in the TT-02 thread and I even posted the "TTGT" class rules my club followed. Basically, box stock Tamiya TT-02 with ball bearings (any kind), USGT tires, and a set of CVD shafts in the front as the stock dog bones tend to fall out. Go have a read.
What happened to the OP? Post 1 is sosidge's reply.
