how to deans?
Old 04-04-2006, 02:27 PM
Default how to deans?
how can i go from micro plugs to deans, i ask because i want to upgrade my mini lst with a brushless system but ive read that they only work well with deans.
cazato is offline
Old 04-04-2006, 05:34 PM
speedracer008's Avatar
i went to deans...not sure if u used the same plug to start...but i juck cliped the end, and sottered on deans
speedracer008 is offline
Old 04-05-2006, 11:36 AM
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Yes, you should just be able to cut the wires and solder the deans plug on.
MarkA is offline
Old 04-05-2006, 08:47 PM
Platinum_Racing's Avatar
Deans are $2 a set and have the instructions on the package. Just make sure you get the wires right for the ESC and battery, or you may be in trouble when you plug it in for the first time!
Platinum_Racing is offline
