Go Back  R/C Tech Forums > General Forums > Rookie Zone
Servo savers: Onroad yes, offroad no : Why? >
Like Tree7Likes
  • 1 Post By GerryH
  • 1 Post By Juglenaut
  • 2 Post By mrreet2001
  • 1 Post By killer rock
  • 1 Post By Roelof
Old 07-26-2021, 01:16 PM
Default Servo savers: Onroad yes, offroad no : Why?
So what's the general consensus on the use of servo savers?
I generally don't see them on modern buggies, and yet they're used in on-road.
What's the thinking behind this? Shouldn't off-road be larger impact forces?
Should we be OK running on-road without savers, given a metal gear servo?
Xtracrispy is offline
Old 07-26-2021, 02:17 PM
the rc guy's Avatar
yes to both
the rc guy is offline
Old 07-28-2021, 10:16 AM
GerryH's Avatar
Trader Rating: 26 (100%+)
Because of the way servo savers work, racers don't want them. So onroad cars and offroad trucks/buggies geared towards racing typically don't have them. The problem is lateral forces caused by high speed corners on a high traction track can overcome the spring in the servo saver and cause inconsistent steering.
That being said, there are still a lot of racing offroad vehicles with servo savers built into the steering rack, especially 1/8 scale.
petersen114 likes this.
GerryH is offline
Old 07-28-2021, 10:38 AM
the rc guy's Avatar
Talking
so again what are you saying use them? or what ? if most 1/8 scales offroads vehicle have them built in.clueless.
Old 07-28-2021, 07:05 PM
Trader Rating: 19 (100%+)
There are ways to so to speak eliminate the saver or minimize it.
The plastic saver bell at least on the 8ight OG-4.0 is a weak point and has to be dremel’d at where the front part of the saver top arm mates on top the saver top as it moves forward and backward on the saver bell. To create a evenly rooted wear pattern a groove has the be made to seat the front of the lip into the plastic or it will round out and stretch the saver bell oblique.
Juglenaut is offline
Old 07-28-2021, 07:10 PM
Use them.. imo
If a good sustainable design, otherwise if problematic. Find solutions that work. I do recommend savers, or a servo that can take the send-it abuse.. no plug intended.
Offroadrcracer likes this.
Old 07-29-2021, 12:46 PM
mrreet2001's Avatar
It's real easy. If you want to get the edge no matter the cost, even if means rebuilding / replacing a servo after a minor crash then do not use servo savers. If you hit the boards all the time and / or are not consistent enough to notice the fraction of a second you would gain by not having them (or you bash and not race) then use a servo saver.
Juglenaut and garnt like this.
mrreet2001 is offline
Old 07-29-2021, 02:07 PM
Totally agree.
Just know if one goes solid, aluminum, maxed spring, glued.. make sure the servo can take a jump without issues. Chances are a servo behind a saver needs to be upgraded as well.
Sir 51D3WAYS likes this.
Old 07-29-2021, 02:14 PM
The plus on the 8ight og-4.0 is there was an aluminum bellcrank setup and with the proper servo the saver can be locked.
Old 07-30-2021, 08:15 PM
Location: northern Indiana southern Michigan all depends on the day.
My thoughts. Excluding 4wd anything asply sct 1/8 buggy and 1/8 truggy. The 2wd rc cars just don't have the traction and weigh to break good quality servo. Not saying enough hits won't still break one but you more likely to break something else(rtr servos excluded). The surface also tends to give away far more then asphalt, cement barriers, cement roads, carpet covered concrete(wood too).
The on road rc cars have less rolling resistance, and often achieve faster speeds then their off-road counterparts coupled with the higher traction and harder surfaces tend to break servos more often. There also a fact that servo saver on the on road cars actually softens up the steering decreasing rollovers At speed on the high traction surfaces.
killer rock is offline
Old 07-31-2021, 01:14 AM
Sir 51D3WAYS's Avatar
On anything offroad, 4wd 1/10 or bigger I would strongly recommend using one. The forces involved in 1/8 scale are immense and can murder servos no problem at all. So best to setup the saver properly. I don't know why people like to lock them down and run a a servo with ridiculous torque to compensate, to me it looks like asking for trouble.
2wd offroad isn't necessary for savers, too light or if it is a truck, the tyres are too poofy and act as an excellent bumper/saver themselves.
Onroad imo is generally necessary for piece of mind, unless you run mod and are of course talented enough to run at that level.
Sir 51D3WAYS is offline
Old 07-31-2021, 06:06 AM
Roelof's Avatar
"Onroad yes, offroad no"
Nope, is not true. 1/10 Onroad TC has no saver at all, as a driver you have the choice to use a saver or just a servo lever on the servo.
In most offroad cars (for sure 1/8) there is a saver build in in the steering mechanism. With an adjustable springtension you can adjust is to what ever you want.
But yes, a saver can be disturbing if there is play on it or they are weak.
Juglenaut likes this.
Roelof is offline
