Go Back  R/C Tech Forums > General Forums > Rookie Zone
Tamiya TB-01 and runner ESC problem >
Old 04-04-2006, 02:56 AM
LaMusica's Avatar
Default Tamiya TB-01 and LRP Runner ESC problem
My TB-01 doesnt seem to be running and the steering is way wrong. The motor doesnt run with that specific ESC but on another its fine.
What should i do?
LaMusica is offline
Old 04-04-2006, 03:44 AM
Rossco's Avatar
what do u mean steering is way wrong? center the steering trim on your controller, adjust the servo horn so that the wheels are as straight as possiable, the fine tune with your steering trim again
Does the ESC work? has it been damaged? water gotten onto it? shorted out? overloaded?
Rossco is offline
Old 04-04-2006, 06:08 AM
LaMusica's Avatar
Well i'm not sure but when i turn my controler off and my car still on it makes a hissing sound. Whne its normal the Led light blinks but my battery is ok.
Well i'm thinking of getting a new speed controler but i'll wait first.
LaMusica is offline
Old 04-04-2006, 02:10 PM
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
You are mean't to turn the transmitter off last, car first. What exactually is it doing? What set-up are you running?
Cheers
Drift_Buggy is offline
And what transmitter are you running?
Cheers
Old 04-04-2006, 07:10 PM
Joel Lagace's Avatar
How about taking 5minutes to type out a proper description of what is happening. What works what doesnt? Also what gear are u using?
"My TB-01 doesnt seem to be running and the steering is way wrong" Thats a great thead title but it tells us nothing, pretty much impossible to offer advise with no info.
Joel Lagace is offline
Old 04-04-2006, 08:48 PM
LaMusica's Avatar
Default Ok
Ok ok here i'll post more info.
The ESC is a LRP runner. The motor is 17 T. The gears are stock. The transmitter is a Sanawa Blazer. The steering is fixed(did that just now) but the motor isnt working, when i put it in my other car its fine. There is a hissing sound that i think comes from my ESC or Servo. What should i do?
All these things came from my Uncle who used to RC but stopped so he gave them to me.
LaMusica is offline
Old 04-05-2006, 01:58 AM
Rossco's Avatar
what model runner is it, the old runners could only handle 20 turn so ya coulda cooked it, how is it geared? disconnect the servo and see if it still makes the sound
Rossco is offline
Old 04-05-2006, 02:16 AM
What esc is in the other car that the motor was working in?
Cheers
Old 04-05-2006, 03:34 AM
LaMusica's Avatar
Its all done now all i had to do was re-wire it then change the pinion gear, now i need to get a new shock mount because i just wreked it
LaMusica is offline
Old 04-05-2006, 03:36 AM
Rossco's Avatar
wow thats a good effort :S a shock mount rewireing an esc
Rossco is offline
Old 04-05-2006, 04:35 AM
LaMusica's Avatar
No no no Rossco I rewired the ESC, Receiver and Servo. I just ran it around the park here and the shock mount broke off. You think i can just glue it together?
LaMusica is offline
Old 04-05-2006, 04:39 AM
Rossco's Avatar
you could but it wouldent be as good as a new one, ur better off gettin a new one is u can
Rossco is offline
Old 04-08-2006, 01:28 AM
LaMusica's Avatar
Well ok.
LaMusica is offline
