Go Back  R/C Tech Forums > General Forums > Rookie Zone
Recommendations for a quality Soldering Iron? >
Like Tree5Likes
  • 4 Post By mushroomed
  • 1 Post By 0010
Old 07-11-2021, 11:36 PM
Default Recommendations for a quality Soldering Iron?
Mike MM is offline
Old 07-12-2021, 01:08 PM
Hakko FX-888D, plus get a wide chisel tip and some nice Kester 63/37 solder.
mushroomed is offline
Old 07-12-2021, 01:18 PM
I carry this one with me in my trackside equipment: Small soldering station
At home, I have the older version of this one on my bench: Benchtop soldering station
Weller and Hakko make good quality soldering equipment as well.
If you are looking for a bench top unit, you may want to look in to one that has the hot air tool incorporated. The hot air tool is nice if you are using heat shrink tubing.
MikeMM likes this.
0010 is offline
Old 07-16-2021, 12:55 PM
motorXhead's Avatar
I have a really good bench station but the one that i like and use the most i got from aliexpress for ~$12. soldering iron its got a digital display and has the wide flat tips you need for soldering motor wires etc. only issue i have had with it is being careful of the temp adjustment buttons as to not hit them while soldering because of placement of them while holding it but not a big deal. this is also compact enough to bring to the track which the stations are not.
motorXhead is offline
