Go Back  R/C Tech Forums > General Forums > Rookie Zone
Need help finding a pinion gear >
Old 12-12-2020, 07:57 AM
SerpentCT4S's Avatar
Trader Rating: 95 (96%+)
Default Need help finding a pinion gear
I need help finding a pinion gear.
Here are the specs I need:
-Mod 0.4 pitch
-2mm inner diameter for motor shaft
-Grub screw
-Size of gear maybe 10-14t
Im using it on a WPL D12 truck. I found some helicopter pinions that work and fit my motor shaft, but I'd like ones that have a grub screw. The ones I have now will have to be glued onto the motor shaft.
Here is what I have now, but I need something with a grub screw.
Please let me know if you have any ideas on where to get the pinion I described!
SerpentCT4S is offline
