Wltoys14401
Old 06-08-2020, 11:01 PM
Default Wltoys14401
When I hold car all wheels spin. When it's on ground all the power is coming from the front wheels. Is it a rear diff problem
Lawless86 is offline
Old 06-11-2020, 10:48 AM
Mirkinator's Avatar
Could be. Or a driveshaft is half broken, loose gear, wheel hex is stripped. Something that is preventing the wheel from spinning under power. Im not familiar with any of the WL toys rigs, but if it has a rear diff you should be able to lift the car up, spin one rear wheel one direction and the other should automatically go the opposite direction. Then while you are spinning the rear wheel, hold the other rear wheel so its stopped and it should then try to move the motor as you continue spinning. Feel for cogging or any issues at these steps. I have also had broken shocks/bulkheads/towers etc. do this. Can cause a geometry issues where the front gets all the power. But those are typically easy to notice.
Mirkinator is offline
