Go Back  R/C Tech Forums > General Forums > Rookie Zone
Need Advice for my Cat K1 >
Like Tree2Likes
  • 1 Post By Mahjik
  • 1 Post By Sir 51D3WAYS
Old 05-31-2020, 02:21 AM
Default Need Advice for my Cat K1
Recently bought a second hand Cat K1 with most of the upgrades to K1 Aero done. I have 2 problems :
1. A lot of the time when going over jumps it drops the rear end and spins 180 degrees and usually lands on its roof.
2. What is the result of turning my motor degrees from 30deg to 25deg its a Zombies 13,5T.
Any help would be greatly appreciated as I m returning to the sport after a 25 year absence.
Johnnymac1965 is offline
Old 05-31-2020, 04:38 AM
Sir 51D3WAYS's Avatar
1. Your question is unclear.... How does it spin 180? How does it land on its roof by the rear end dropping?!
When jumping, you should accelerate up the face of the jump and maintain a fixed throttle position, (whatever you left the jump with) and try and land with the same throttle position. Resist the temptation to lift off the throttle, only doing so gently to bring the nose down if at all necessary.
2. Reducing motor timing will reduce speed and temperatures. Increasing motor timing will increase speed and temperatures. A reduction of 5 degrees will only generally be small effect however. 30 deg should be fine though.
Sir 51D3WAYS is offline
Old 05-31-2020, 09:27 AM
This isn't the most technical article, but scroll down to where it talks about "Techniques for jumping and landing":
https://racingrccar.com/how-to-jump/
Basically, you need to learn how to use the throttle to control the car in the air.
Johnnymac1965 likes this.
Mahjik is offline
Old 05-31-2020, 10:08 AM
Thanks for the help, I tend to take the throttle off once the car starts the jump, you have given me something to practice.
Old 05-31-2020, 10:09 AM
Thanks for me the article has been helpful, I guess a lot of practice is in order
Old 05-31-2020, 11:05 AM
Don't worry, it took me a couple of years and loads of broken parts to get the hang of it.....
Old 05-31-2020, 01:53 PM
the rc guy's Avatar
a 4 wd when driven correctly. you should be able to make a jump then hit brakes and drop your car almost strength down on any jump.
the rc guy is offline
Old 05-31-2020, 06:01 PM
Yep I have to agree, there will be quite a few broken parts. Thanks for the reply.
Old 05-31-2020, 08:07 PM
You can also look at VRC Pro:
https://store.steampowered.com/app/335070/VRC_PRO/
It can help a bit. However, air control is a little easier in the sim than real life but it does help.
Mahjik is offline
