Go Back  R/C Tech Forums > General Forums > Rookie Zone
Change all connectors >
Like Tree1Likes
  • 1 Post By the rc guy
Old 05-30-2020, 01:45 PM
Default Change all connectors
Hi,
I'm trying to switch poorly constructed connector with deans. I want to change wall charger connector, battery cable connector, one from electronic speed control to the battery. Is changing all the connectors to deans a good idea?
View
Eefpod2000 is offline
Old 05-30-2020, 02:15 PM
the rc guy's Avatar
YES 100%
Billy Kelly likes this.
the rc guy is offline
Old 05-30-2020, 03:24 PM
If you are changing the connector on a battery, cut each wire separately. Don't cut both wires at the same time.
Mahjik is offline
Old 05-30-2020, 03:42 PM
Thanks for your help guys and yeah I heard about cutting only one wire at a time. Does cutting one wire at a time apply to all the connectors too or just the connector on a battery?
Old 05-30-2020, 05:18 PM
the rc guy's Avatar
get in the habit of only cutting 1 wire at a time. then you wont make the mistake of cutting 2 wires at once.. and its only the battery wires. I use a weighted plastic clip to hold wire out away from the other.
