Go Back  R/C Tech Forums > General Forums > Rookie Zone
Steering Issues on Tamiya XV-01 >
Like Tree2Likes
Old 05-29-2020, 03:11 AM
  #16
fyrstormer's Avatar
I've been using Spektrum receivers with Hitec servos (even the Hitec HS-7955TG "ultra torque" servo) on 6 volts or less for years without any problems. Never used Savox so I can't comment, but I've heard mixed reviews. Never heard anyone complain about Hitec servos.
fyrstormer is offline
Old 05-29-2020, 06:36 AM
  #17
the rc guy's Avatar
I also run Hitec servos... and just recently has my servo act strange .would not hold a turn,would jump right or left at its whim(whenever)..I was running a castle esc with a 13.5 motor,,took a ubec to solve the issue. I went thru everything I could think of...
the rc guy is offline
Old 05-29-2020, 11:44 AM
  #18
IndyRC_Racer's Avatar
Originally Posted by sleeperx
I swapped the servo with another one (a Savox SC-1252MG) and still did the exact same thing. After more testing, I find that if I hold the steering just slightly left off center, it drives straight. As soon as I let go of the wheel, it'll start turning. Now, I'm really beginning to think I need to set something up on the Spektrum. I watched a bunch of videos on Youtube, but found nothing. And I can't find much reading material.
To me, brown out means it cuts out power? But, there's no issue with power.
SLEEPERX started this thread. Please re-read their most recent post (I have quoted it above). Based on their own response/observations, I would guess that they need to Adjust the steering subtrim on their transmitter (They are using a Spektrum DX5c).
The issue could also be related to the stock Tamiya servo saver. I have found that if you over-tighten the screw that holds the servo saver to the servo AND you are using a high torque servo, the plastic U shaped "spring" in the servo saver may have problems returning the servo saver back to center. In other words, the servo saver can get "stuck" slightly off-center which results in the steering not returning back to neutral. This may result in the car randomly steering to the right or left depending on which position the servo saver gets stuck in. While the stock servo saver should work under normal circumstances, it is worth upgrading it to the Tamiya High Torque Servo Saver as suggested previously.
It is common in this hobby to purchase many things second hand or used. Thankfully most manufacturers offer manuals to download for free. Here are a few links that might help...
Tamiya USA manual download page.
https://www.tamiya.com/english/rc/manuals.htm
Spektrum DX5C manual in .pdf format (from Horizon Hobby)
https://www.horizonhobby.com/pdf/SPM5100-Manual-EN.pdf
I hope this information helps.
IndyRC_Racer is offline
Old 05-29-2020, 03:04 PM
  #19
fyrstormer's Avatar
Maybe there's a marginally-bad pin connection, or a cracked wire, that is causing the servo to receive less power than it should, and the Castle BEC is able to shove the required amperage through the bad connection.
Anyway, based on the OP's most recent post, it really sounds like the servo trim is off-center. Or possibly the servo horn was knocked off-center by an impact and needs to be repositioned.
Old 05-29-2020, 09:04 PM
  #20
I've made a video of it. As you can see the first go at it, it turns left. When I reverse, it comes back straight. Then I hit the little trim button once and it seems to stop the sharp turns. And I guess the drift is something I have to straighten out. But, it's the initial turn that is weird. Unless I hit the trim button once, it does the turn.
youtu.be/Op_zd1FfFJE
sleeperx is offline
Old 05-29-2020, 10:00 PM
  #21
Sir 51D3WAYS's Avatar
Based on that video, I suggest you apply a little trim to the right.
Then see what happens. Post up a second vid.
Sir 51D3WAYS is offline
Old 05-29-2020, 11:48 PM
  #22
fyrstormer's Avatar
Okay, so you actually have two problems. The slight pull to the left is a simple alignment or trim issue (depending on whether you want to correct it by adjusting the turnbuckles on the car or the settings on the controller). The sharp turn to the left is very strange, but since you say it stops happening after you adjust the trim even a tiny bit, that means there is something physically wrong with your controller. I think you need to make another video of the same problem happening repeatedly in a larger space than your balcony, and then return the controller for repairs along with a link to the video showing the problem.
Old 05-30-2020, 08:54 AM
  #23
Originally Posted by fyrstormer
You definitely do not need a 10 amp BEC to power the servo in a rally car. Those things are complete overkill for all RCs, even rock crawlers
Agreed for the rally car... but there are high torque crawler servos out there that will pull 4-5A under full load, and plenty of crawlers with multiple servos out there or run dual steering servos, winch, lights etc... not hard to add up to needing a 10A BEC for a crawler.
To me the issue in the video does look like a physical problem with the steering (could be horn too tight, or too loose, something binding).I suspect a physical problem rather than something with the radio. The sharp turn could be the servo finally pushing past whatever it is binding on, or a loose horn flopping into that position under load. Does the steering sound crunchy when you turn it? It could even be a stripped internal gear on the servo.
mushroomed is offline
Old 05-31-2020, 11:00 PM
  #24
fyrstormer's Avatar
Again, servos do not pull amperage. (nor do any other electrical devices.) They accept and try to use whatever amperage the battery can shove through them, and that depends on their electrical resistance.
Dual steering servos use less power than single steering servos, because the dual servos are under less strain and waste less energy as heat. The only exception to this is if the single servo is incapable of steering the wheels at all, in which case the dual servos appear to use more power, but they still use less power than a stronger single servo would require to do the same work.
LEDs use a few milliamps each. Certainly newer LEDs can handle having multiple amps pushed through them, but RC lights lack the massive heatsinking required to run LEDs at those power levels, so RC lights are limited to 0.05 - 0.1A per LED at most.
Transmission servos also use a few milliamps each, unless the shift linkage is binding, but obviously that problem is solved by fixing the shift linkage, not by shoving more power through the transmission servo.
Mostly, crawler guys have a similar mindset to the guys who used to build all-metal T-Maxxes -- they believe their RC requirements are more extreme than everyone else. It's super-easy to sell excessive equipment to crawler guys.
Old 05-31-2020, 11:46 PM
  #25
Not sure about the rest of it, but can agree to this!
fyrstormer likes this.
