Go Back  R/C Tech Forums > General Forums > Rookie Zone
air filter foam oil >
air filter foam oil
air filter foam oil
Old 03-19-2006, 10:21 AM
Default air filter foam oil
What can you use for air filter foam oil?
derrickh_00 is offline
Old 03-19-2006, 04:59 PM
j0ej0eTMAXX's Avatar
I would suggest not using anything but actual foam filter oil sold at your local hobby shop. You do not need to use the expensive stuff, but you definitely need to use the right oil and always make sure you have your foam filter well lubricated when running your engine.
j0ej0eTMAXX is offline
Old 03-19-2006, 10:34 PM
Platinum_Racing's Avatar
I posted a reply in your other post. Instead of making multiple threads, it's alright to bump the current thread to the top by posting in it. For example, right now this thread is about 5 from the top, but after I finish typing and click the "Submit Reply" button, it will become first on the list. All you need to do to bring your thread back into the limelight is to post a reply in your own thread that says something like "TTT (To the Top) or Bump."
Both of those are good ways to bring your post back into public view, but use these techniques sparingly. All threads have a useful life, and some will last longer than others. Eventually threads will slowly get pushed back by more current news, so don't be dissapointed if your thread gets forced to the bottom of the page in due time.
Just a friendly tip, that's all!
Platinum_Racing is offline
Old 03-20-2006, 06:27 AM
Default The multiple posts
It was an accident! Couldn't figure out how to delete the duplicate.
Old 03-20-2006, 05:04 PM
Meh... nobody's perfect!
