Go Back  R/C Tech Forums > General Forums > Rookie Zone
Odd question - RC hovercraft >
Old 11-08-2019, 02:05 PM
Default Odd question - RC hovercraft
I have a 6 channel radio and receiver. The machine uses one fan/motor for lift, one for thrust and one servo for rudder.
I want to put the lift fan on one of the switch actuated channels on my radio (on, off, reverse settings)... however, I do not want the lift fan to be at full power at all times. Is there something that I can install before or after the ESC that would allow me to limit the RPMs of the lift fan?
feralucce is offline
Old 11-09-2019, 07:43 AM
the rc guy's Avatar
tekin esc might help they have current limits you could use ..
the rc guy is offline
Old 11-11-2019, 03:40 AM
Sir 51D3WAYS's Avatar
I believe it is possible to set endpoints on the switch channels. Use them to limit power output.
I think you may be able to use a servo modulator..... but I don't know how.
If your Esc allows it, program it to limit output power.
Personally, assuming you are using an aircraft style controller, I would put the lift fan control on the throttle channel (the one without the spring), and use the other gimbal for steering/ forward thrust. This way, you can set the lift fan to a fixed throttle amount and leave it there. Steer can be put on either gimbal, but you must have a steady thumb to prevent the lift throttle position from changing.
Sir 51D3WAYS is offline
