Go Back  R/C Tech Forums > General Forums > Rookie Zone
rear loose on throttle >
Old 03-10-2006, 12:02 AM
teabag's Avatar
Default rear loose on throttle
my ta05 is loose when i turn and on the throttle, more so going left and not going right? stiff up the rear?
teabag is offline
Old 03-10-2006, 12:42 AM
MarkA's Avatar
Trader Rating: 21 (100%+)
First if the car turns differntly one way than the other, set the tweak.
Next, you would want to soften the rear, not stiffen it.
MarkA is offline
Old 03-10-2006, 06:44 PM
Superkarter's Avatar
going to a harder spring on the back would be less weight on it and therefore less traction making it worse
Superkarter is offline
Old 03-13-2006, 10:31 PM
nf_ekt's Avatar
Trader Rating: 115 (100%+)
You can get a set-up book from XXX-MAIN, I bought one and it helped make alot of things clear. Read up on the droop section it has a big affect on handling. Have you tried softer rear springs? Buy this book and read it .
nf_ekt is offline
Old 03-14-2006, 06:22 PM
Bud
http://users.pandora.be/elvo/intro.htm
Bud is offline
Old 03-18-2006, 11:35 PM
Kyosho3PKRacer's Avatar
May want to check that your servo is travelling same amount in both directions aswell that is going to make it turn more one way than the other.
And check the shock positions are in same hole, my friend actually had one in middle and the other side in the top hole
Kyosho3PKRacer is offline
