glue front bumper to pan ??
Hy y'all…
I need to find either the right glue or tape to attach the front bumper to the pan. The bumper is cut from dense foam rubber and presses against the inside of the Lexan body. It needs to be firmly held to the pan to absorb impacts.
I've tried double sided tape but it pulls away from the foam rubber after a few hits. The rubber needs something that penetrates and gets a grip. I think some kind of glue that gripped the rubber could be used to give the tape a surface to hold that would last.
Anybody solved this problem?
tia
tia
contact cement...weldwood
