Go Back  R/C Tech Forums > General Forums > Rookie Zone
How do i remove servo arm from HPI ss-20wr servo >
Old 05-24-2019, 11:55 AM
Default How do i remove servo arm from HPI ss-20wr servo
Hi, i just bought my first car, the hpi hoonicorn. I obviously had a slight mishap after the first 15 minutes and destroyed the SS-20WR servo. (sheared one of the gears inside the servo). I bought a new savox metal one but i can't seem to remove the arm from my old servo. I can't find any instructions about it ether online or in the manual... Does anyone know how to remove the metal gray bolt? I tried doing it with the wrench but the plastic around it looked like it would break before the bolt would move... there has to be a trick to it, right? I would post an image but the site doesn't allow it yet since i'm new.
Snejk is offline
Old 05-24-2019, 12:15 PM
the rc guy's Avatar
most of the time there is a small phillips head screw holding arm on servo ..how do you know old servo arm will fit new servo?not all servo use same size arm.
the rc guy is online now
Old 05-24-2019, 12:16 PM
the rc guy's Avatar
after screw is removed you can wiggle old horn off
Old 05-24-2019, 12:21 PM
I used a flashlight to peer inside the big nut and ther eis indeed a small screw inside, thanks. As for the second question... i will pray?
Snejk is offline
Old 05-24-2019, 12:25 PM
It fits Thank you!
Snejk is offline
Old 05-24-2019, 12:27 PM
the rc guy's Avatar
np..drive on.
