Go Back  R/C Tech Forums > General Forums > Rookie Zone
Everything Operates Backwards (acceleration/steering) >
Like Tree3Likes
  • 2 Post By ahe243
  • 1 Post By BladeRunner24
Old 04-14-2019, 06:37 PM
Default Everything Operates Backwards (acceleration/steering)
Hello everyone
I am new to the forum. I love RC cars.I am having a problem with a team Losi xxx that i bought used on Ebay. Everything is backwards. By that i mean that if you turn the controller left it will go right and if you turn right it goes left and it is not just the steering it also goes forward slow and backwards fast and the speed is opposite of what I expected. I have a FS-GT3B transmitter and FS-GR3E receiver and Hobbywing Quicrun 1060 brushed esc. Does anybody have suggestions on how to fix it?
Thank you for your help.
nike124 is offline
Old 04-14-2019, 06:38 PM
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 85 (100%+)
Need to reset your radio, i.e. servo reverse. Have you got the manuals
1/8 IC Fan is offline
Old 04-15-2019, 04:56 AM
you should be able to reverse it on your transmitter there should be an option or switch that says norm/revs or something like that for steering and throttle, flip that and you should be good to go. I do not know anything about that radio and a quick search on a-main came up with nothing but even the cheapest and or most high end radios have that option
Billy Kelly and Joshmcgil90 like this.
ahe243 is offline
Old 04-15-2019, 06:01 AM
To add to the above response you should be able to recalibrate the esc for throttle endpoints.
faqcya is offline
Old 04-15-2019, 06:58 AM
the rc guy's Avatar
you dont need to reclibrate esc .. switch radios 2 channels fwd to rev or rev to fwd.that will fix you issues.
the rc guy is offline
Old 04-15-2019, 07:02 AM
OverGeared's Avatar
Default FS-GT3B Instruction Manual
Here's a link for the FS-GT3B manual, you can just turn to page 16 to see the step-by-step instruction on how to reverse the steering and throttle channels (usually the steering channel is ch1 and throttle is ch2).
https://www.manualslib.com/manual/10...?page=2#manual
OverGeared is offline
Old 04-15-2019, 06:53 PM
BladeRunner24's Avatar
Try switching wires into esc to fix the fwd reverse problem.
BladeRunner24 is offline
Old 04-15-2019, 07:16 PM
thank you guys I will give it a try this weekend.
nike124 is offline
Old 04-15-2019, 07:39 PM
Location: northern Indiana southern Michigan all depends on the day.
Reverse channel one/steering. (Already stated)
I need a clarification when you pull trigger to you/squeeze the trigger what happens.
killer rock is online now
Old 04-15-2019, 07:45 PM
At first, the car went backwards (fast) when I pulled the trigger. I swapped the wires to the motor and now it goes forward (slow) when I pull the trigger. It's as if the forward speed is the speed for reverse.
nike124 is offline
Old 04-15-2019, 07:53 PM
Sounds like it's all in your transmitter settings, just reverse everything and u should be good to go
killer rock likes this.
Old 04-15-2019, 08:14 PM
switch the wires so forward is fast and reverse is slow(Only swap 2 doesn't matter which 2). Then reverse the trigger in the radio settings if needed so pulling the trigger makes it go forward. And you'll be Golden brown.
PS Have a battery ready too, it's play time.
Edit: Sorry missed that this is brushed, thought it was brushless. Soo there are only 2 wires
Old 04-16-2019, 05:18 AM
OverGeared's Avatar
Sounds like you needed to redo the ESC calibration with your radio transmitter.
Old 04-16-2019, 06:54 AM
the rc guy's Avatar
this slow in fwd now that you switched the polarity of the said brushed motor tell all .switch the Ch1 and ch2 directions to the opposite of what they are on now only fix you have. after you switch motor wires back to what they were.
