Charging 4s LiPo help
I知 trying to charge a reaction battery 4s 6500mah 15.2v battery on my protek 610ez charger . Should I set it to balance LiPo mode, 6.5amps and to 6500 capacity as well as 15.2 volts. Also will it shut itself off once the battery is charged or do I have to babysit the charger and watch it?? Thanks guys
I would always charge in a LiPo bag I知 not that rookie. I知 asking if the charger will shut itself off once the battery is technically charged to it痴 current rating
set charger for balance at 4 cells.. and desired amps. the charger will charge battery by itself but be safe and use lipo bag or box.. babysit charger . be safe.charger will charge battery all by itself and stop charge .set charger to beep when finished..
never leave any battery charge unattended .to risky IMHO..
About how long will it take to charge a 15.2v 4s 6500mah battery charging at 1c and 6.5 amps. Like an hour or so or something like that ??
Technically it should take a hour..but sometimes all depends on how the charger balances the lipo..a hour might be a tad more
One last thing . It showed a voltage cutoff on the menu on the charger default is 4.2v. Should I leave it at 4.2v considering this is a 15.2v 4S battery .. thanks again guys for the help
yes as I would just leave it unless your racing, as with my i charger in have my voltage set at 4.21 volts per cell, and by the time the charger shuts off and I get the car ready for the track the voltage is right at 4.2 volts per cell, which is the limit for the batteries, so before I changed that setting on my charger the pack would be 4.17 volts per cell, not a lot of difference, but enough for racing in my opinion
If this is a 4 cell. then voltage is 16,8 when charge is finished...Id be very weary about charging to 4.21 volts a cell..
ok as I just need to ask why you would be weary of that as we are talking .01 volts per cell, so 1 cell, 2 cell, and so on as I have not read anything that states .01 volts more in a cell is bad, but then again maybe I am wrong, as resting charged voltage always seems to diminish a little before the race
