Go Back  R/C Tech Forums > General Forums > Rookie Zone
Inaugural Run >
Inaugural Run
Like Tree3Likes
  • 3 Post By dmourati
Inaugural Run
Old 12-29-2018, 06:27 PM
Default Inaugural Run
Today I took out my new to me Yokomo YZ-4SF for its inaugural run. I chose a nearby baseball diamond.
My first reaction was wow does this car handle nice. I played with the edge of traction by giving throttle in the turns and was easily able to slide the corners. The grass in the outfield was a little too long and wet to get much speed through but I could create a mini jump on the transition from the infield dirt to the outfield grass. There were some other obstacles in the second base area where a bunch of leaves/dirt had piled up to make it bumpy.
I wasn't able to get any photos of me running it but I did take some after. It took maybe 45 minutes for me to clean it up. I'm surprised how much junk got into the car underneath the body.
Derrty
Side windshield no longer lets any light through
Satisfied
Inside took some of the field with it too.
I flipped the car 3 or 4 times. This happened when I hit the transition from infield to outfield laterally during a turn or when I tried to turn too hard in the grass. Otherwise, no crashes!
dmourati is offline
