Go Back  R/C Tech Forums > General Forums > Rookie Zone
1/12 pan car spur gears >
Like Tree2Likes
  • 1 Post By 1/8 IC Fan
  • 1 Post By Roelof
Old 10-09-2018, 11:10 AM
Default 1/12 pan car spur gears
im confused about these spur gears. i have two older crc 1/12 cars i was going to run in a 1/12gt class. i bought these things used years ago and don't know anything about 1/12 scale. what spurs will fit?
sacky07 is offline
Old 10-09-2018, 06:49 PM
DesertRat's Avatar
All of them. Buy something from 76-80 teeth to start with for the spur for stock racing.
DesertRat is offline
Old 10-10-2018, 03:21 AM
hey thanks! so all the diff balls are the same size? what balls and what diff plates? (the round disks) are good to buy and from where? how long do they usually last? class rules are 45/78 gears with a 21..5
sacky07 is offline
Old 10-10-2018, 03:58 AM
1/8 IC Fan's Avatar
Trader Rating: 97 (100%+)
Most good online shops carry all you need. CRC carries what came on your car.
TQ has a good selection too:
https://www.tqrcracing.com/shop/prod...06&s_maker_id=
https://www.tqrcracing.com/shop/part...arts_p_id=9744
sacky07 likes this.
1/8 IC Fan is offline
Old 10-15-2018, 07:34 AM
what diff ball size does the kimbrough sper use?
sacky07 is offline
Old 10-21-2018, 04:30 AM
wingracer's Avatar
Trader Rating: 24 (100%+)
Almost all pan cars use the same spurs and 1/8th diff balls. There are some oddballs out there though. For instance, CRC and some others played around with smaller diff balls and rings for a while.
wingracer is offline
Old 10-21-2018, 07:04 AM
Roelof's Avatar
Most balls are 1/8" (3.17mm), I know Tamiya uses 3mm balls but handle perfectly 1/8"
These balls are standard used in bicycles In most bike shops you can get a box of 100 balls for just a few bucks. Last I scored 100 ceramic balls for just 14 dollar on Alixpress.
sacky07 likes this.
Roelof is offline
Old 10-22-2018, 07:38 AM
how many balls are typically used? old gear i took out had 8 even spaced. with the new kimbrough gear i bought that isn't possible. should i just fill up all the holes in the outer ring?
sacky07 is offline
