Go Back  R/C Tech Forums > General Forums > Rookie Zone
Brushless motor break in? >
Old 11-16-2017, 05:08 PM
DMD
DMD's Avatar
Default Brushless motor break in?
I just would like to get some opinions regarding breaking in a new motor. I just picked up an ORCA RT 17.5 and I didn't know if it is necessary to break in a new motor. Any suggestions would be greatly appreciated.
DMD is offline
Old 11-16-2017, 05:17 PM
I've never broken in a brush less motor. Just be sure to not overheat a motor. I would start with a conservative fdr and go taller from there. I don't like my motors to get over 160.
Kelseyrc is offline
Old 11-16-2017, 07:18 PM
DMD
DMD's Avatar
Thanks. I was planning to add some oil to the bearings and run it. I'll try not to exceed 160. Thanks again for the info.
DMD is offline
Old 11-22-2017, 09:52 PM
no such thing needed for a brushless motor. the break in was for brushed motors because it has...brushes that touch a moving armature.
there is 0 contact in a brushless motor.
burnnitro is offline
Old 11-24-2017, 06:56 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 222 (100%+)
break it in just like a silver can dip it in a bowl of water
lol just joking leave the motor alone
Marcos.J is offline
Old 11-24-2017, 07:03 PM
the rc guy's Avatar
I would never put a brushless motor in a can of water.. if you need to break it in then your not doing something correct this is brushless no need to break in.. might use a micro lube on bearing only.
the rc guy is offline
Old 11-25-2017, 09:53 AM
MarkA's Avatar
Trader Rating: 21 (100%+)
You missed this part...
Some 13.5/17.5 motors do emit a bit of a burning smell on their first run (Reedy and Schurrspeed ones I know for sure do it) even while they're still at a safe temp but it goes away and as mentioned above, there's no need to break in a bl motor in any way.
MarkA is offline
Old 11-26-2017, 09:05 AM
DMD
DMD's Avatar
Default Tips
Thanks for all of the input. Just checking.
DMD is offline
Old 11-29-2017, 07:55 AM
I pulled out my SCT which hasn't seen the light of day in 3 years last month and put a receiver in it and went racing. I guess I should have checked the bearings because it hit 192 degrees. It still runs well.
buster8787 is offline
